will this fit an 1994 z28
http://www.ecklers.com/product.asp?p...dept%5Fid=1220
and if not is there one that does????
Re: will this fit an 1994 z28
Since it indicates it is only for the 92-93 Corvette LT1, it would appear it may be limited to use on the intake manifold without the groove for the diagonal cross-over tube at the front of the fuel rails. Note also that the "gap" for the fuel hard lines is on the wrong side for the F-Body. I would think if it would fit the 94-96 LT1 Corvettes with the cross-over tube, they would indicate that it fits 92-96.... but they don't.
Why not call/e-mail Ecklers and ask?
Just an idea....(If you havent already) powdercoat or paint your intake nicely with some hi-temp ceramic engine paint, then polish the fins on top of your intake like a mirror(then clearcoat it)......not only will it look awesome , but it will let the heat escape unlike the metal pieces that shield engine parts and hold heat in even more......
94z28jbw
Sep 8, 2002 03:22 PM
