Air Pump by-pass
Old May 18, 2004 | 09:43 PM
htrd69's Avatar
Air Pump by-pass
I have 2 friends that have LT1's and both are having check engine codes for air pumps. Is there a way to by-pass, trick, or eliminate the computer here? I live in KY, so emissions isn't a problem. One is a 94 TA and the other is a 97 Z28. Any help is appreciated.
Old May 18, 2004 | 09:51 PM
Spinner's Avatar
Usually codes wont throw as long as there's a fuse in the system. If your getting one however, the only way around is to have the codes programmed out.
www.madz28.com
Old May 18, 2004 | 10:30 PM
The 94 (OBD-I) will not set a code as long as the fuse is good. The 97 (OBD-II) requires that the programming be changed.
HectorM52
Jul 30, 2017 11:46 AM
linz
3rd Gen / L98 Engine Tech
Oct 22, 2015 07:59 AM
Magenta_Hearts
Mar 22, 2015 03:36 PM
Magenta_Hearts
Mar 5, 2015 07:01 AM
