Do I need the front O2 sensors?
Old May 18, 2004 | 04:54 PM
RBS_97Z28's Avatar
I already have the rear O2's PCM deleted. I'm going to order some LT's for my 97 and I was wondering what I should do about the front O2's. I'd prefer to just leave them unhooked if possible.
Thanks in advance!
Old May 18, 2004 | 05:23 PM
Yeah, you need the front ones for proper fuel management.
Old May 18, 2004 | 06:34 PM
Wildwill2855's Avatar
No you dont man
Ive been without them for about 1 1/2 years now and it will run smoother without them try it if you dont like it install it back!
Old May 18, 2004 | 07:59 PM
Makaveli's Avatar
do you just plug em into the catless y pipe? or what would you do with them if you deleted cats?
Old May 18, 2004 | 08:44 PM
96capricemgr's Avatar
The front O2s are what make fuel injection work so well, without them you migh just as well run a carb, they are what tells the pcm wether it is rich or lean so it can adjust accordingly.
RE AND CHERYL's Avatar
If you remove them completely from a OBD I car it will suck down gas like ther is no tomorrow. An OBD II car will know there is something wrong and limit how much gas it eats, but it won't run right and will loose power.
You can install the O2 sensors in the header collectors even if you don't have cats installed. It will never pass emissions though if you have them in your area.
Old May 18, 2004 | 09:16 PM
Originally posted by Wildwill2855
No you dont man
Well, it will certainly run without them working, but I can't imagine how there is efficient fuel management without them.
Old May 18, 2004 | 10:34 PM
Heatmaker's Avatar
Advanced Member
Once upon a time long ago... I had a ful ltank of gas... I ran my car with no 02 sensors on her at all.... so my car sat on jack stands... I turned my car on only 3 times.... THREE Times... sometimes I'd let it idle for 5 minutes... sometimes I just turn her on and then off.... then all of a sudden... my Needle was on top of the E ..... WTF??? I was baffled indeed.... Another Case for Mulder and Skully.
Magenta_Hearts
Mar 29, 2017 08:54 PM
BigWil
Mar 29, 2015 12:24 PM
Jazsun
Dec 29, 2014 12:14 PM
Jul 4, 2005 05:00 PM
