Air Pump by-pass
Air Pump by-pass
I have 2 friends that have LT1's and both are having check engine codes for air pumps. Is there a way to by-pass, trick, or eliminate the computer here? I live in KY, so emissions isn't a problem. One is a 94 TA and the other is a 97 Z28. Any help is appreciated.
Usually codes wont throw as long as there's a fuse in the system. If your getting one however, the only way around is to have the codes programmed out.
www.madz28.com
www.madz28.com
stockssn2o
May 25, 2015 08:54 AM
Magenta_Hearts
Mar 22, 2015 03:36 PM
Magenta_Hearts
Mar 5, 2015 07:01 AM
