air pump and egr?
Re: air pump and egr?
It will have no affect on the engine. You will notice no performance gains, other then the small weight loss. AIR only runs for a couple minutes at startup, to help the cats heat up and start working faster. EGR never operates at idle or at WOT. Just when you are running at lower RPM, and lugging the engine. That's a condition that increases combustion chamber temps, increasing NOx formation and promoting detonation (knock). The recycled exhaust gas cools the combustion temperatures.
You can get both diagnostics "programmed out" of the PCM. If they know what they are doing, they can avoid the "system not ready" flag that may cause failure if they hook up to your ALDL connector for emissions. There are also electronic "spoofs" to simulate the presence of the EGR system, but none for the AIR system that I am aware of.
stockssn2o
May 25, 2015 08:54 AM
Magenta_Hearts
Mar 5, 2015 07:01 AM
armedtrigger
Feb 24, 2015 08:30 PM
