Fuel Leak?
Old Sep 9, 2006 | 10:48 PM
1994greenz28's Avatar
Fuel Leak?
I have a 94 z28 auto...under hard acceleration there is a gas smell in the car...there are no leaks from the tank or the fuel lines...I believe that the smell is coming from the engine bay...I have check the engine at idle and cannot see any leaks form the fuel lines, the fuel rail, or the injectors...not sure what else it could be...any ideas would be great...Thanks
Old Sep 9, 2006 | 11:22 PM
RyanD's Avatar
Re: Fuel Leak?
running really rich?
Old Sep 10, 2006 | 06:01 PM
OBE1 95Z28's Avatar
Re: Fuel Leak?
There's a charcoal canister mounted in the driver's side rear wheel well. The canister may be failing or the vacuum line to it may be disconnected causing the fuel smell.
kallcium
V6 Tech
Oct 7, 2015 03:39 PM
ChrisFrez
Feb 22, 2015 08:47 AM
Alex Barnes
Jan 24, 2015 10:21 PM
Jessie4tin
Jan 7, 2015 08:53 AM
blac94Z
Nov 24, 2014 07:12 PM
