air pump differences
Old May 14, 2013 | 09:06 AM
Chet1185's Avatar
Why are my 95 Camaro and TA's air pumps different. The Camaro which I need to replace has just a plug on the side with the wires going into the pump where my TA has a plug with two wires going into the pump and two going to a solenoid with two vacuum nipples. I was hoping to swap them out and I can't understand why they would be different.
Posted from Camaroz28.com App for Android
Old May 14, 2013 | 01:55 PM
Re: air pump differences
They aren't. What you are likely seeing is pre and post pump recall (probably same as later model). The later ones have more stuff on them.
Old May 14, 2013 | 08:56 PM
Chet1185's Avatar
Can they be swapped at all?
Old May 14, 2013 | 10:26 PM
If you use all the extra stuff from the one car, it should work. That's apparently what they did when the recall was done. I never took mine in for the recall, LOL.
Old May 14, 2013 | 11:17 PM
Chet1185's Avatar
I will try it out. Thank you
HectorM52
Jul 30, 2017 11:46 AM
linz
3rd Gen / L98 Engine Tech
Oct 22, 2015 07:59 AM
cmdeshon
Dec 27, 2014 10:06 AM
CamaroZBoy
Aug 16, 2002 10:03 PM
