Air foil making LOUD sucking noise?!
Old Jul 1, 2005 | 02:17 AM
AlwaysCode390's Avatar
Question Air foil making LOUD sucking noise?!
Well I just installed an air foil in my car the other day and I am either hearing a LOUD sucking type sound from the front of my throttle body or I am hearing my alternator whine like crazy. It happens when I first start it up before the car warms up then goes away until I start to drive again. Its so loud that I hear it echo off the cars when I drive by over my 3" flowmasters!!!! I hate it....I can hear it in the cab of the car too. Do these foils normally do this or do you think I should replace my alternator ( bad bearings? ) or just lube it up with silicone spray?! Thanks---
Old Jul 1, 2005 | 02:57 AM
Black1995Z's Avatar
Re: Air foil making LOUD sucking noise?!
Rule out the airfoil, thats silly lol..
... id check the alt or maybe a new belt. you can just pick up a can of belt dressing for a few bucks and see if that helps
Old Jul 1, 2005 | 06:33 AM
captskin's Avatar
Check your intake Phelum, it could be that its not on all the way...happened to me not too long ago...
try it out!
Old Jul 1, 2005 | 09:16 AM
Dave '97 Z28 M6's Avatar
try it out!
I agree.
Old Jul 1, 2005 | 01:27 PM
Lightbulb Re: Air foil making LOUD sucking noise?!
I just went out and started it and noticed the sound is coming from the alternator, DAYAM!!!! Will dressing fix it or are the bearings going out? I am wondering why it is loud sometime and then not so loud sometime.....thanks!!!
Old Jul 3, 2005 | 08:10 PM
It was also the fact that I needed to put RTV on the new gasket I replaced when taking off the TPI upper plate during the foil install, lol!!!! Vacuum leak!!!
jcamaro95lt1
Jan 24, 2015 08:21 AM
ScottZ
Mar 3, 2004 01:34 PM
94z28jbw
Sep 8, 2002 03:22 PM
Rich_z28
Aug 29, 2002 10:44 PM
turbo_Z
Aug 19, 2002 10:50 PM
