Air foil making LOUD sucking noise?!
Well I just installed an air foil in my car the other day and I am either hearing a LOUD sucking type sound from the front of my throttle body or I am hearing my alternator whine like crazy. It happens when I first start it up before the car warms up then goes away until I start to drive again. Its so loud that I hear it echo off the cars when I drive by over my 3" flowmasters!!!! I hate it....I can hear it in the cab of the car too. Do these foils normally do this or do you think I should replace my alternator ( bad bearings? ) or just lube it up with silicone spray?! Thanks---
Re: Air foil making LOUD sucking noise?!
Rule out the airfoil, thats silly lol..
... id check the alt or maybe a new belt. you can just pick up a can of belt dressing for a few bucks and see if that helps
Originally Posted by captskin
Check your intake Phelum, it could be that its not on all the way...happened to me not too long ago...
try it out!
try it out!
I just went out and started it and noticed the sound is coming from the alternator, DAYAM!!!! Will dressing fix it or are the bearings going out? I am wondering why it is loud sometime and then not so loud sometime.....thanks!!!
It was also the fact that I needed to put RTV on the new gasket I replaced when taking off the TPI upper plate during the foil install, lol!!!! Vacuum leak!!!
94z28jbw
Sep 8, 2002 03:22 PM
Rich_z28
Aug 29, 2002 10:44 PM
turbo_Z
Aug 19, 2002 10:50 PM
