Which air filter.. Please read
I have a 93 TA, and wanted to know which air filter would fit right at the end of my throttle body. I dont know the part number that everyone uses for this... I am going to fabricate something for the summer to read air through a home made ramair duct and when it is cool, I am going to just use the IAT 4.7ohm resistor which should read somewhere around 57degrees from what I have read.... Anyone done this?
Let me know, thanks.
Tim
Tim
I don't think many 93 owners put the air filter directly on the throttle body. It would be picking up the very hot air directly from the back of the radiator.
And, in a 93, you don't want to "trick" the ECM with a false inlet air temperature. Since the 93 is running "speed-density", it need an accurate inlet air temperature to accurately calculate the "density" part of the equation.
95chwagon
Jan 13, 2015 09:19 PM
z28projects4ever
9
Jul 16, 2002 07:48 PM
