Air bag light -- What connections to check?
When I come home for spring break I'd like to fix my air bag light problem. I am eventually going to remove them, but not until the car gets a cage, seats, and a set of 6-point harnesses. Until then I want to keep them in and functional.
I know about the ground post by the red battery terminal. Sanded that and cleaned the surface, still have the light.
Fuse is ok.
Where are all the yellow connectors? I know there is one at the base of the steering column, and one by the glovebox, and then a connector to the control unit under the center console. Are there any others?
Are there any other reference grounds that I should look at?
Thanks!
Fuse is ok.
Thanks!
If you are trying to turn off the airbag light (your post is a little vague) there is a yellow connector behind the glovebox. The airbag light is on a brown wire and the yellow connector has B1 embossed on it at that wire. If you cut it the light will go off.
squarehead
Jan 15, 2015 07:02 PM
95chwagon
Jan 13, 2015 09:19 PM
Jul 4, 2005 05:00 PM
danielbmx
Aug 27, 2002 11:11 PM
