Air Bag light! Make it go away!
Old Sep 11, 2003 | 10:32 PM
CrippleFightin's Avatar
My air bag light is on. I am not sure how to to fix this. I know its because I spun the steering wheel while the steering linkage was disconnected, but how exactly do i go about fixing this problem?
Old Sep 11, 2003 | 10:45 PM
If you spun the wheel when the shaft was disconnected, you broke the leads on the SIR coil. A new coil is a $100+ item.
Old Sep 11, 2003 | 11:11 PM
93formula's Avatar
ouch
Old Sep 11, 2003 | 11:32 PM
Bud M's Avatar
The quick and dirty fix is to cut the wire to the air bag light. There is a big yellow connector under the glove compartment. The airbag light is a brown wire that is marked B1 on the plastic connector (at least that's how it is on a 93, your year may be different).
Old Sep 12, 2003 | 04:11 AM
Holy Lord! Screw getting that for awhile. I assume it wont mess anything else up if I leave it as it. Just the airbag wont deploy right?
Old Sep 28, 2003 | 07:29 PM
lietuvis's Avatar
what's the part number for the SIR coil. Where is it located. Anyone has pictures.
Old Sep 28, 2003 | 07:37 PM
Damn I guess I might need that stuff too huh.....
Old Sep 28, 2003 | 07:46 PM
bpipe95's Avatar
i did the same thing when i had my steering unhooked for the motor change. where is the thing located does anyone have a picture and can i please have a part number.
thanks
brad
squarehead
Jan 15, 2015 07:02 PM
95chwagon
Jan 13, 2015 09:19 PM
siguy
Nov 27, 2014 10:07 AM
Jul 4, 2005 05:00 PM
