Aftermarket Tach w/shift light in A4?
Old Aug 29, 2007 | 10:38 AM
trans9_5am's Avatar
Is is a good idea to run an aftermarket tach and shift light when you have an a4? I know the factory tach isnt that accurate so is having a tach and shift light a good idea or is it more accurate to just let the transmission do the shifting on its own?
Old Aug 29, 2007 | 10:42 AM
94_PatriotRed_Z's Avatar
just let the trans shift on its own because you will never be as fast a accurate as the computer
Old Aug 29, 2007 | 11:16 AM
Z28LT1_Just_Nasty's Avatar
Its automatic for a reason, if you wanted to shift manually should have gotten a manual. The tach might be fine to use, but I laugh at anyone who has a shift light in an A4.
Old Aug 29, 2007 | 11:48 AM
Javier97Z28's Avatar
Moderator
Unless you have a full manual valve body in your car.. leave the shift light OUT.
Old Aug 29, 2007 | 12:25 PM
trans9_5am's Avatar
ok thanks guys....i fully understand!
Brandon
Old Aug 29, 2007 | 01:32 PM
IrocSS85's Avatar
yeah for you, def. let the pcm do the shifting. for me, however I DO manually shift mine. cause its a 700r4 swap. and the shift points while it D or OD are too low rpm. plus on the older trannies manually shifting brings on full line press as opposed to what the TV cable THINKS the line press. should be.
mr28
Apr 20, 2016 05:44 PM
ldtantlinger92
Jan 19, 2015 01:26 PM
mr28
Nov 23, 2014 11:11 AM
