abs inop light turned off now ses light is on?
Old Aug 28, 2007 | 03:22 PM
lt1swap95's Avatar
I have been driving my 97 lt1 camaro for a while with the abs inop light on and today it turned from abs inop to ses. Then when I hit the brakes the low traction light came on twice then didnt do it the whole way home. Does any one have any idea what happened? Could it just be a bad sensor or am I lookin at something worse?
Old Aug 28, 2007 | 03:53 PM
Guest47904's Avatar
Guest
Take it to AZ and scan it.
Old Aug 28, 2007 | 03:54 PM
moparman's Avatar
Is the SES still on?
Old Aug 28, 2007 | 08:05 PM
lt1swap95's Avatar
yes
Old Aug 28, 2007 | 09:05 PM
moparman's Avatar
You need to get the code(s) pulled. Autozone can pull the SES codes. Write'em down and post'em up.
Old Aug 29, 2007 | 02:19 PM
lt1swap95's Avatar
(I think this is what it was called) second air injection malfunction I believe but I deleted the codes and the Abs Inop went off and so did the ses light. I think I have a vacuum leak because from the glove compartment I can hear a pssssssssss... What do you guys think it could be?
Old Aug 29, 2007 | 02:21 PM
A hiss from that area of the dash would be the vacuum for the HVAC controls. Open things up so you can find the source of the noise.
Old Aug 29, 2007 | 02:22 PM
moparman's Avatar
What was the exact code number?
Old Aug 29, 2007 | 02:27 PM
lt1swap95's Avatar
I just read on another thread that it is the code 29 which is secondary air injection malfunction.
Old Aug 29, 2007 | 02:51 PM
lt1swap95's Avatar
btw I have the fans grounded to stay on all the time and my mechanic took off the whole air intake to get to my thermostat to put a 160* in so could that have affected something? Those are the most recent things done which I do not know if that has anything to do with it.
Old Aug 29, 2007 | 03:44 PM
killpro's Avatar
does your SES light turn on as soon as your car does? or does it take a few minutes for it to turn on?
because i had the code 29, and it was just my air pump, ended up going bad, but i just unplugged the pump, and replaced the fuse, and now the SES light is gone.
jj_burchiel
Mar 21, 2015 12:51 AM
dluna333
15
Mar 13, 2015 12:30 PM
Gtpguy
Jan 26, 2015 04:50 PM
bfmv13trivium
Jan 14, 2015 09:57 AM
A's 91 Z28
Dec 7, 2014 12:09 PM
