Aftermarket Tach w/shift light in A4?
Is is a good idea to run an aftermarket tach and shift light when you have an a4? I know the factory tach isnt that accurate so is having a tach and shift light a good idea or is it more accurate to just let the transmission do the shifting on its own?
yeah for you, def. let the pcm do the shifting. for me, however I DO manually shift mine. cause its a 700r4 swap. and the shift points while it D or OD are too low rpm. plus on the older trannies manually shifting brings on full line press as opposed to what the TV cable THINKS the line press. should be.
