Aftermarket or stock oil pump driveshaft replacement?
Old Feb 18, 2011 | 02:53 PM
Kurt Crosbie's Avatar
My pump shaft recently broke, so I'm going to need another. Should I just get another stock unit or is another stronger replacement I should go with?
Sent from my ADR6300 using Tapatalk
Old Feb 20, 2011 | 11:13 AM
bdc95ta's Avatar
Re: Aftermarket or stock oil pump driveshaft replacement?
Are u running the stock cam?
Old Feb 20, 2011 | 04:22 PM
96capricemgr's Avatar
Damage like that is pretty much always associated with either a cam with the wrong gear or a HV oil pump.
The only "aftermarket" direct replacement I know of is the Heron Performance billet one but I believe that uses the stock gear it is a billet body.
Old Feb 20, 2011 | 05:07 PM
bdc95ta's Avatar
I think it's the cam 2. I'm running a MSD billet 1; with a Comp Cams composite gear (will work on everything), but not cheap.
Old Feb 20, 2011 | 07:22 PM
SC/TA's Avatar
The one from Herron is just the housing. You will still need a new gear, something is not meshing with the cam gear. You need to find out what kind of cam you have. you may need a different type of oil pump gear
Old Feb 22, 2011 | 12:43 PM
I'm hearing that high oil pressure with a lot of RPM can cause this problem. It has a high pressure spring in it (so I'm told), so I'll make sure and take it back to stock when I take it out.
Old Feb 22, 2011 | 03:51 PM
SC/TA's Avatar
I think it was the high volume pumps that some people had problems with, not high pressure.
Old Feb 22, 2011 | 05:51 PM
Comp 233/239 112LSA
~.590' lift w/1.6 rockers.
Old Feb 22, 2011 | 08:53 PM
red 95 z28 lt1's Avatar
that exact thing happened to me with my le2 cam and a stock gear. looked exactley the same... had to change out the gear for a compatable gear.
Old Feb 22, 2011 | 08:58 PM
Just telling us it is a Comp cam does not tell us if it is the right material.
Old Feb 22, 2011 | 09:05 PM
I'll find out by tomorrow what material the gear is on the cam. In the meantime, I found a melonized oil pump drive gear (GM PART # 10456413) on gmpartsdirect.com. Would I just take the gear off the current shaft?
If I use the melonized gear, could I continue to use the high volume oil pump?
Old Feb 22, 2011 | 09:59 PM
RamAir95TA's Avatar
It's the high VOLUME, not the high PRESSURE that wears the gear. High volume pumps have larger impellers. Larger impellers move more oil and take more power while providing more resistance. The pressure is governed by a pressure relief spring that opens and bypasses oil back into the pan when the springs rated pressure is exceeded.
HectorM52
Jul 30, 2017 11:46 AM
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
Jazsun
Dec 29, 2014 12:14 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
