Aftermarket Pulleys..worth the HP gain?
Old Nov 15, 2004 | 07:51 PM
  #31
MarkyMark's Avatar
Re: Aftermarket Pulleys..worth the HP gain?
Originally Posted by madwolf
If that is the alternator pulley that comes in the kit I mentioned, then I will take it.
My car idles at 900/950 so it should be OK. I don't like pulleys myself, but I would like to give this setup a try since it's the first one I see that replaced the whole balancer. (I am planning to dyno it of course, to see what and if there are any improvements)
Yea it comes in the 900 rpm kit....shoot me a pm if you are interested.
If you have a solid electrical system you should be ok, but I was also having some other issues (and still am) like there is a amp draw on my battery when the car sits and wont start after a day of sitting without being started.
If you end up doing a before and after dyno with this then I would love to see how it turns out......later.
Old Nov 15, 2004 | 09:17 PM
  #32
Antz97ZNJ's Avatar
It wont be a whole lot but you will feel a differance in throttle responce...fyi, years back i had a few buddies w/ 93 and 94 fbodies that had charging problems on there cars...they both had to take them out
Old Nov 15, 2004 | 10:48 PM
  #33
TransAmGT's Avatar
Just take the belt off at the track and put it back on between runs....mine ran .2 sec faster and 3 mph faster
Old Nov 16, 2004 | 12:58 AM
  #34
Heatmaker's Avatar
Advanced Member
My pulley kit has killed 2 altinators... def charging issues.... Not sure if it was worth the 3 extra... ftlbs
Kinglouui
May 26, 2016 11:05 AM
Bigfatrat
Parts Wanted
Oct 16, 2015 04:48 PM
CARiD
Sep 30, 2015 05:44 AM
SEOJustin
Sep 24, 2015 04:39 PM
colts0455
Sep 22, 2015 02:03 PM
