aftermarket oil pan options?
Old Feb 1, 2005 | 11:47 PM
  #16
1racerdude's Avatar
Re: aftermarket oil pan options?
OK,Thanks
A local guy was running one just 2 weeks ago,runs 1.3's 60' and toted the wheels and didn't finish the pass. Big mess on the track.
Just wondering,Thanks.
Old Feb 2, 2005 | 08:56 AM
  #17
lillbush5555's Avatar
I have a Moroso 7Qt oil pan on my 383...pixs can be seen here http://community.webshots.com/album/230034686gXusiQ
Matt
Old Feb 2, 2005 | 09:01 AM
  #18
Birdie2000's Avatar
The Milodon pan for these cars is very nice.
Old Feb 2, 2005 | 05:58 PM
  #19
Originally Posted by 1racerdude
OK,Thanks
The only damage this car ever suffered was when he dropped it hard and smashed the oil pan... fortunately it was the stock pan and didn't cost a whole lot to replace. 1.3X 60-fts.
http://cjcfo.fbody.com/members/injun.../DCP02600z.jpg
Old Feb 2, 2005 | 06:04 PM
  #20
Brent94Z's Avatar
Super Moderator
http://www.brentfranker.com/gallery/album93/PICT0003
Old Feb 2, 2005 | 06:05 PM
  #21
1racerdude's Avatar
From what I understand the engine let loose at the front,indacating lack of oil from the pump ie. uncovered pickup. The pump and drive was said to be in good shape afterward.
I am not willing to take that chance with mine or anyone elses engine for a couple of hundred dollars.
Old Feb 2, 2005 | 06:10 PM
  #22
greatwhitez's Avatar
i've got the milodin pan, and it works well w/ my 396 lt1. no clearance problems, and no leaks so far. It looks pretty too!
Old Feb 3, 2005 | 06:03 AM
  #23
n2oblkz
Guest
Posts: n/a
Posted by: 1racerdude
Right, if I am going to spend the money on a buildup, which will probably be my only one ever, I will wait a while longer and make sure I have all the best parts and have it done right.
Old Feb 3, 2005 | 06:25 AM
  #24
'93 formy ...'s Avatar
I also have a Canton, though I haven't finished my 396 stroker yet so I can't really say how good the pan is (as far as whether or not it fit's properely and seals with no leaks.
What I can say is that from the looks of it, it's a top notch piece. All the welds are perfect and I even filled it with water as someone suggested and there were no leaks at all.
To me, it looks like a great peice. Only time will tell, but my mechanic told me he's put in literally dozens of these things these past few month's and no ones had any problems at all. (Apparently Canton had some quality control problems in the past but they re-vised their design and corrected all their problems a while back)
I say go with the Canton.
Click th link below for a few pictures of my Cantol oil pan:
Pictures of the LT1 Canton "T" oil pan - CLICK HERE
Old Feb 3, 2005 | 06:52 AM
  #25
n2oblkz
Guest
Posts: n/a
I would really love to buy a Canton because it does look like a quality piece, but I just can't get myelf to do it after all of the bad that I have heard about them. A buddy of mine has one on his 10 sec. 396 Z and it leaks like crazy (from the welds!). I'm not going to spend all of that money on a buildup just to have a new engine leak all over my new garage floor!
Old Feb 3, 2005 | 10:06 AM
  #26
Canton's been in the business for a long, long time. If they were really that bad, do you think they'd still be in business?
Even the best companies produce a few duds from time to time, don't let that stop you from buying their products.
That's just my opinion though.
Good Luck
Old Feb 3, 2005 | 06:46 PM
  #27
96capricemgr's Avatar
A lot of bad companies have been in buissiness for a LONG time, many start out good then once the name is established let the product go to hell, the name recognition carries them through. As a shining example I submit Fram, probably the worste filters made yet clearly the biggest sellers. Too few people do any meaningful research. Not saying Canton is bad just that your argument is flawed.
Old Feb 4, 2005 | 09:33 AM
  #28
After following the threads on this board, and at least 2 other popular F-Body boards that I also moderate, for more than 7 years, I have seen far more complaints posted about the Canton pan than I have ever seen about the stock pan.
Old Feb 4, 2005 | 10:17 AM
  #29
Birdie2000's Avatar
Injuneer, did you add a different windage tray to the factory pan, or are you referring to just keeping the stock one in place?
I bought a 383 blower engine that has excellent parts in it, and was well planned out, and they used the stock pan. I figure that it'll work fine since there seems to have been a lot of research done with regards to the engine as a "package", and I've seen your input and Rich's as well, but I still can't help but wonder if it's worth throwing another pan on there. If there's any simple mod to better keep the oil on the pickup in a stock pan, that would be great.
Old Feb 4, 2005 | 10:44 AM
  #30
LT4383's Avatar
On all these leaky Canton pans I wonder if it is the gasket and install procedure that might have something to do with it. I read several posts about people spinning bearings after doing a cam swap as well, generally that has more to do with poor install and cleanliness than anything else.
