after jacking up motor, oil pressure guage?
Old 09-21-2004, 05:06 PM
96LT1TX's Avatar
Hi, every time I jack up my motor my oil pressure guage is maxed out and wont move at all, makes me scared to drive it. Does anyone know what I did? It happened both times I took out my oil pan, which is why I have to raise the motor a little.
I am about to go fix the burnt plug wire (*$#@(*$&) and get this thing down the track...
so any advice is appreciated.
96LT1TX is offline
Old 09-21-2004, 05:21 PM
agrsiv95's Avatar
Re: after jacking up motor, oil pressure guage?
Check the wire on the oil pressure sending unit at the back of the intake. If it is loose/unhooked it will do that.
J
agrsiv95 is offline
Old 09-22-2004, 12:24 AM
revtime's Avatar
Also check to see if you broke the sending unit.
I broke mine while putting in the rebuilt tranny.
Its close to the firewall and if the engine tilts back it will break the sending unit.
revtime is offline
Old 09-22-2004, 12:44 AM
slimdawson's Avatar
What they said. I broke mine putting the motor in. It only has to be cracked a little bit so check it good.
slimdawson is offline
Old 09-22-2004, 01:51 AM
atljar's Avatar
Ditto
atljar is offline
Old 09-22-2004, 02:44 AM
96LT1TX's Avatar
this oil sending unit... you mean the thing I screwed back into the oil pan?
I am going to try and find a picture of what I'm looking for, that is the same thing I was told broke the last time, and I had some ****ty shop fix it... not really but they tried.
thanks again
96LT1TX is offline
Old 09-22-2004, 03:14 AM
Spinner's Avatar
The thing in the pan has NOTHING TO DO WITH YOUR OIL PRESSURE READING AT ALL, PERIOD.
Now then, your oil pressure sensor/sending unit are on the back of your intake.
Spinner is offline
Old 09-22-2004, 05:39 AM
Mtrhds94Z's Avatar
That's the 'low oil' sensor..
Mtrhds94Z is offline
Old 09-22-2004, 01:59 PM
You can always count on Shoebox to have a good photo of practically everything.
http://shbox.com/1/oil_pressure_sensor.jpg
Injuneer is offline
Old 09-22-2004, 03:32 PM
96LT1TX's Avatar
ok, I rewired that thing in that picture... or at least reconnected it to the right wire w/ a wire connector type deal.. does it have to be sodered together? we just used the wire connectors and clamped each side hard, and it doesnt seem to read right yet...
sorry for my newbieness, I thought that was what the sender unit was, but I thought we fixed it too...
96LT1TX is offline
Old 09-22-2004, 04:17 PM
WS Sick's Avatar
Originally Posted by robvas
On the LS1 they point straight up.
Why are they made of plastic?
So that they sell a bunch from us breaking them....lol
WS Sick is offline
HectorM52
07-30-2017 11:46 AM
transam_388
03-15-2015 11:53 AM
Z28countrymama
01-22-2015 02:50 AM
07-04-2005 05:00 PM
GigaMp3z
02-20-2003 02:57 PM
Quick Reply: after jacking up motor, oil pressure guage?
