after car sits more than two three days it burns oil on startup?
Old Feb 9, 2004 | 07:14 AM
ChickenScreamer94's Avatar
Can this be the vavle seals? When i start it after it sits a while and then rev it a little to like 1.5k, it like gurggles on the way down and sounds like it wants to die? I am guessing it is valves seals or IM leak? Is this ok to do?
Old Feb 9, 2004 | 12:11 PM
SVT Killer LV's Avatar
sounds like valve seals, and boy is that gonna be a fun job to do in the car..
Old Feb 9, 2004 | 12:36 PM
jbird's Avatar
Yeah, it's probably worn out valve seals. It will be a fun job in the car, but it can be done. You could probably check shoebox's site for instructions on getting to the seals (taking off the rockers and springs and stuff) without dropping a valve into the cylinder. http://shbox.com/1/4th_gen_tech1.html
that's shoebox's tech page, you should be able to find some stuff on there. Even a valve spring swap or something should give you decent instructions. Or you could always just leave it the way it is.
Old Feb 9, 2004 | 07:31 PM
I wasnt hoping to hear that. I am just gonna leave it like that then. It isnt like it uses oil, just that if it sits for 3 or 4 days it burns a little on startup, you can just smell it and see a very little cloud of smoke.
If there was only a heads and cam foundation...
Old Feb 9, 2004 | 09:24 PM
Laymaster's Avatar
well if it only consumes very minor oil/oil change (say like 1/2 quart over 3,000 miles) I wouldn't worry too much about it at this stage. If you are going to do a heads/cam in the future you could probably put it off until then, however as well all know when we have a project it always takes a lot longer to get to it than we anticipate, so just monitor it closely and should it start to become an issue, you may want to push up the heads/cam project.
Old Feb 10, 2004 | 03:19 AM
MentalCaseOne's Avatar
Its only gunna get worse. And the oil will get to your Cats (if you still have any) and or coat your 02's. And Oil burning trough the valve guides causes misfiring too. Not to mention valve deposites that will eventually choke your engine and cause knocking and pinging.
Well at least a couple of years down the line.....
Marvin
bfmv13trivium
Jan 14, 2015 09:57 AM
Scottylt1
Jan 8, 2015 02:48 PM
Scottylt1
Dec 4, 2014 12:31 PM
USAirman93
Nov 24, 2014 03:37 PM
Snoman73
Nov 17, 2014 07:22 PM
