AFR "Hydra-Rev
Old Feb 5, 2004 | 08:01 AM
Coolformula's Avatar
AFR "Hydra-Rev
If I put 2.6 roller rockers would this be a goo spring kit for it. How much is the hydra rev kit anyway. I didnt see it on there [ricing pdf. thanks
Old Feb 5, 2004 | 08:35 AM
rskrause's Avatar
Moderator
The Hydra Rev kit does not contain valve springs. It is a device that applies additional spring pressure to the lifter bodies and (in theory) allows higher revs without using stiffer valve springs. There are a number of people who report using stock springs with 1.6 rockers. I never personally did the measurements, but by the specs using 1.6 rockers would put the stock springs quite close to coil bind. But as I said, many have reported doing this without problems.
Rich Krause
Old Feb 5, 2004 | 09:26 AM
Thanks. I think im just going to get lt4 springs and 1.6 pro magumns. I got most of the other bolt ons. tankhs
G-BODYT56
Jan 14, 2022 11:14 PM
RUENUF
Mar 13, 2016 03:37 PM
Bigtoyz97
Sep 21, 2015 01:44 PM
FryedClutch
Sep 1, 2015 08:24 AM
bunker
Aug 21, 2015 10:21 AM
