AFR 220 Lt4 heads on a stock LT1 :)
Old Sep 4, 2003 | 10:30 PM
xxsaint69x's Avatar
Would i be nuts if i put some AFR 220 Lt4 heads on my car?
I hear they are little bit too big for a Street Application
What would happned if i put them on?
Marcin
Old Sep 4, 2003 | 10:46 PM
TreySpeed's Avatar
On permanent vacation
Re: AFR 220 Lt4 heads on a stock LT1 :)
Marcin
I'm no head expert, and i am just going purely based on intuition so its probobly wrong and I hope someone corrects me if i am wrong-
but to my understanding, a bigger port = less velocity.
Less velocity is a bad thing, very bad- especially if you have a big cam and want to make any power down low.
Id really like to hear a pros opinion
Old Sep 4, 2003 | 11:06 PM
WS6T3RROR's Avatar
i'm no pro either, i just know a few things. and that big of a port on a stock 350cid lt1 with your 306 cam is going to do nothing good for you down low. if you wanted a huge port i'd go the small cam route. but since you already have a 306 i would suggest something in the 200cc range or the 195's. ported stockers are however cheaper and turn out at ~195-200cc's (in my exp). that cam would probably do better for you with some more compression as well so how about just a set of well ported stockers and some angle milling with impala head gaskets. just my $.02
Old Sep 4, 2003 | 11:23 PM
atljar's Avatar
Yes you will lose some downlow, but that can be made up for in gearing Up top those will scream, i would do it
Old Sep 4, 2003 | 11:55 PM
Umbrae's Avatar
We all know that damn cam is too big for stock heads anyway... but did you listen
Try em out. You never know what could happen. If they dont work out, they'll be easy to sell im sure.
Keep us posted.
-Cam
Old Sep 5, 2003 | 03:44 PM
xxsaint69x's Avatar
should i stay with CC306 cam or should i go bigger...
Old Sep 5, 2003 | 04:30 PM
Ai's Avatar
Ai
Well if you're going to drop the $ on aftermarket castings, you might as well have someone decent port them... so in the end you're looking at a fair chunk of change (to most people). For most people, I wouldnt spend the $ on aftermarket castings if you're wanting what most want (450-500hp on the stock shortblock w/ a HR).
If you were to run a good 210-220cc port, i'd be running a little more cam .
Old Sep 5, 2003 | 10:06 PM
aBrotze's Avatar
Correct me if I am wrong but don't you have to have the intake cut to work on the AFR 220s ?
Old Sep 5, 2003 | 11:41 PM
atljar's Avatar
GM 847 is calling your name loudly and clearly. Marcin, marcin, are you listening marcin? lol.
Old Sep 5, 2003 | 11:43 PM
96z's Avatar
96z
The hell with that, put a nasty solid roller in it.
Old Sep 6, 2003 | 12:00 AM
TreySpeed's Avatar
pshht, your one to talk about nasty cams
Old Sep 6, 2003 | 01:50 AM
neil350's Avatar
You want to run a 12.30@125 now
Man I agree go solid or go home
LeftoverChinese
Jan 14, 2024 03:03 PM
Steve69SS396
Track Kill Stories
15
Aug 10, 2015 02:45 PM
MadMav
Feb 6, 2015 11:02 PM
Brandon Wittmer
Dec 3, 2014 09:28 PM
