AFR 190's???
Old Dec 25, 2003 | 10:57 PM
30thCamaroZ's Avatar
AFR 190's???
Does anyone know what the AFR 190's flow and can you give me a link to a flow sheet? I would appreciate any info. Thanks, Jarred
Old Dec 25, 2003 | 11:04 PM
Kryckter's Avatar
www.airflowresearch.com ----- they have flow sheets on the product specs page for all heads including the LT1 heads!
Old Dec 25, 2003 | 11:42 PM
the 190's aren't on there as they discontinued them but I found the flow sheets on google. Now I just need to find some for sale hopefully. Later, Jarred
Old Dec 26, 2003 | 10:00 AM
engineermike's Avatar
We flowed a couple sets at Thunder Racing and found 240 cfm peak with one set and 233 with another, versus AFR's advertised numbers of 262 cfm.
The 210's, however, all flowed 280 cfm out the box versus 285 advertised.
Mike
Old Dec 26, 2003 | 12:31 PM
Thanks for the helpful info. What about the 180's or the 195's? I know they discontinued the 190's because supposedly the 180's flow better. Thanks, Jarred
Old Dec 26, 2003 | 12:42 PM
I wouldn't get anything less than the 210's. I'm on my second set now and I like them alot.
The smaller heads don't have as much intake CNC porting as the 210's, 220's, and 227's. No matter if they are 180 or 195, they won't come near 280 true cfm.
Mike
Old Dec 26, 2003 | 12:45 PM
formularpm's Avatar
What type of bench did you flow them on?
Old Dec 26, 2003 | 12:48 PM
Superflow 1020
http://www.thunderracing.com/index.c...n=shopservices
Old Dec 26, 2003 | 01:09 PM
Wild1's Avatar
I thought the larger CFMs reduced port velocity which reduced torque and increases HP. Am I right? So, doesn't it depend on the overall package to determine which head CFM to go with? (Engine displacement, exhaust, intake, cam, etc).
Old Dec 26, 2003 | 01:59 PM
Well here are my cam specs. 242/252 110lobe sep. .580lift with 1.6RR's. So I probably need a head that flows very well what do you think?
Old Dec 26, 2003 | 03:12 PM
Get the 210's.
Old Dec 26, 2003 | 05:09 PM
Wild1's Avatar
For that cam, definately. But I was inquisitive about the limits within the stock bottom end and a mild cam (224/230). Wouldn't the port velocity be reduced with such a mild cam? Wouldn't that disrupt torque? I'm not speaking as an authority, just a question.
Old Dec 26, 2003 | 06:23 PM
http://web.camaross.com/forums/showt...5&pagenumber=2
Old Dec 26, 2003 | 08:53 PM
Wild1's Avatar
Your numbers in the Car Craft article really hit the point. Thanks for the thread.
G-BODYT56
Jan 14, 2022 11:14 PM
Bigtoyz97
Sep 21, 2015 01:44 PM
FryedClutch
Sep 1, 2015 08:24 AM
bunker
Aug 21, 2015 10:21 AM
4586
Aug 2, 2015 01:45 PM
