Afew questions...
Old Jan 30, 2005 | 10:31 PM
SSmoked's Avatar
Afew questions...
I just have afew random questions. I was reading that A.I.R pump thread and someone said all it does is heat up the cat. If i was to take it off and have it deleted from my computer would i still pass emissions? Same for my EGR, if i deleted it would i pass?
Also, i posted this in drivetrain and didnt get much of a response. Anytime my clutch is out their is a rattleing noise comming from the bellhousing. I was thinking its the TO bearing but want to be sure before i pull the trans. Last question, i have 2.73 gears now, how much of a difference will i see if i went with some 3.73's? On dry pavement the car barley spins and has good traction on street tires. How much will that change with 3.73?
Sorry for the stupid questions, i just want to be sure about afew things.
Old Jan 30, 2005 | 10:43 PM
SSmoked's Avatar
Re: Afew questions...
Allmost forgot, i was thinking of some 1.6 RR's. How much will they help me out with my mods in sig?
Old Jan 30, 2005 | 10:55 PM
Spinner's Avatar
Going to need some better valve springs.
Old Jan 30, 2005 | 11:38 PM
SSmoked's Avatar
Whats wrong with the LT4 valve springs? Also if my TO bearing is bad what problems can it cause? Im going on a bit of a trip tomorrow and would like to know if i should take a different car. Thanks.
Old Jan 30, 2005 | 11:42 PM
Birdman7389's Avatar
You will notice a big difference going to 3.73, most of the manual guys go with 4.11 though. The rattle is probably the pilot bearing, could also be the throwout.....
Old Jan 30, 2005 | 11:43 PM
30696bird's Avatar
If your TO bearing goes out you won't be going much further. It may also be your pilot bearing. If that is the case replace it with a bushing. This is just my opinion since I have not seen the car in person so take it for what it's worth. I also am in need of 3.73's, it will make a BIG differance.
Old Jan 30, 2005 | 11:45 PM
30696bird's Avatar
LOL.............there I go being a minute late again!!!
Old Jan 30, 2005 | 11:54 PM
SSmoked's Avatar
If the TO or pilot bearing are bad will it cause any damage to anything?
Old Jan 31, 2005 | 01:11 PM
Spinner's Avatar
LT4 springs would be maxed out on a 305 with 1.6 RRs, you need something with more clearance (and pressure imo)
blkWidow
Apr 20, 2015 09:27 AM
Type_O_Negative_1320
Mar 4, 2004 10:31 PM
KarmaCult
3rd Gen / L98 Engine Tech
May 8, 2003 05:00 PM
KarmaCult
Mar 9, 2003 06:48 PM
ryan2
Feb 21, 2003 01:03 PM
