Adjusting valves - Comp 1.6 RRs - What did i do wrong ?
Old Mar 15, 2006 | 06:37 AM
sabre81's Avatar
Was finishing up my heads/cam swap last night and went to adjust my rockers using the following method...
Piston #1 @ TDC
Adjust:
Intake: 1, 2, 5, 7
Exhaust: 1, 3, 4, 8
Rotate crank 360* (piston #6 should be at TDC right?)
Adjust:
Intake: 3, 4, 6, 8
Exhaust: 2, 5, 6, 7
Problem is, after i did the first set, and turned the crank 360*, most of the rockers i just tightened were loose.. What gives? I was half asleep so i may have just did it wrong,,
What does it sound like i did? Maybe had the wrong poston at TDC?
Old Mar 15, 2006 | 07:09 AM
Javier97Z28's Avatar
Moderator
Re: Adjusting valves - Comp 1.6 RRs - What did i do wrong ?
I'm a fan of the engine running method. It's nowhere near as messy as people say since at idle you don't have a ton of oil coming out of the valve cover area.
Back 'em off one by one till they start clacking, slowly turn the nut until it stops clacking and then give it your preload.
Old Mar 15, 2006 | 07:41 AM
sabre81's Avatar
Even for first startup? I was thinking i should adjust the valves with the car off for the first start and then once it's running ok, adjust while running.
Old Mar 15, 2006 | 07:45 AM
Moderator
I made sure none were "falling off the studs" loose, when the car started up it was fine to work with.
Old Mar 15, 2006 | 07:47 AM
sabre81's Avatar
alright i shall do that. if i end up covered in oil i'm going to cry.
Old Mar 15, 2006 | 07:50 AM
Moderator
Suck it up If they're on too tight, the car won't start, just FYI.
Old Mar 15, 2006 | 07:58 AM
sabre81's Avatar
What lifters did you use and did you use 1/4 turn, 1/2 turn , or 3/4 turn preload?
Old Mar 15, 2006 | 07:59 AM
Moderator
OEM style comp lifters, I went 1/8 turn.
Old Mar 15, 2006 | 08:05 AM
wrd1972's Avatar
I went 1/2 turn past zero lash. No problems here.
Old Mar 15, 2006 | 08:06 AM
1quickTA's Avatar
I just did my rockers and had the same issue. Leave what you just did as a "ball-park" setting, fire up the engine with the covers off and then readjust them with the engine running. And FYI, even after I adjusted mine with the engine running, the rockers still are a tad "loose" in that the move side so side a little if you push on them, but they are always netted to the push rods. I also went 1/4 turn and I have GMPP 1.6 and OEM lifter.
Old Mar 15, 2006 | 08:44 AM
89385formula's Avatar
I don't really like the running method, everytime i have done it oil came out, and cleanup sucks. I always do the one cylinder at a time method where you watch for the exhuast lifter on a cylinder starts to open, then adjust the intake valve, then turn the motor over until the intake valve fully opens and is just about closed, and then adjust the exhaust valve. This is the way I have done it on everything and has worked good for me. I think this is also one of the methods on shoebox's tech pages as well.
Old Mar 15, 2006 | 08:47 AM
HardcoreRM125's Avatar
THats normal. They will be tight as your first adjust them. As you turn it over by hand though, the lifters all bleed down. They will get that "play" in them from side to side. Nothing to worry about.
Do it with it running. Its 10million times easier, Just spin them all down till the poly lock is down and there is no play. Go 1/4 turn past, and your good to start it and readjust.
Also, once you set the preload, tighten the polylock with an allen, then turn the whole poly lock just to snug it up and ensure it will stay tight.
Old Mar 15, 2006 | 08:54 AM
Moderator
Running method takes about uuuuh, 2 minutes per side if that. It's really not that messy.
Old Mar 15, 2006 | 08:56 AM
MeanGreen97Z's Avatar
Use a piece of cardboard to keep the oil from flying everywhere. Works like a charm.
Old Mar 15, 2006 | 09:40 AM
Mkos1980's Avatar
Yup. I also use the motor running method. I always start up a new motor without valve covers so I can jump in and tighten any loose ones or loosen any tight. I usually go 1/4 turn past 0 lash
MadMav
May 25, 2015 09:35 PM
R@mpage
Apr 20, 2015 10:02 AM
Roadie
Feb 16, 2015 10:34 AM
97bowtie
Aug 25, 2002 11:00 PM
Wicked
Jul 25, 2002 04:19 PM
