adjusting valve lash, TDC help
Old Apr 21, 2006 | 10:45 AM
Hawk's Avatar
My crank hub has been off several times, and I can't go by the marker on that.
I'm using shoebox's page as a guide:
http://shbox.com/1/4th_gen_tech2.html#adjust_valves
My problem is, there are 2 valves per cylinder, which one is the intake and which one is the exhaust???
THanks.
Old Apr 21, 2006 | 11:02 AM
terminal_crazy's Avatar
Re: adjusting valve lash, TDC help
Cylinder Heads pn LT1's have valves arranged ExIn InEx ExIn InEx
ie extreme 2 valves & centre 2 valves are exhausts
HTH
Mitch
Old Apr 21, 2006 | 11:07 AM
BUBBA's Avatar
See where the valves line up with the exhaust ports (manifold) those are the exhaust ports, the rest are intakes.
Old Apr 21, 2006 | 01:20 PM
"White Knight"'s Avatar
Use method 3, then the hub doesn't matter. You watch the pushrod/lifter/spring movements.
Old Apr 21, 2006 | 09:10 PM
Hawk's Avatar
thanks for the replies guys, i'm on top of it now
Old Apr 28, 2006 | 01:58 PM
atreyu's Avatar
a
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
2QUIK6
Jul 15, 2015 07:46 PM
FredM
Apr 10, 2015 02:56 PM
