adjusting rr's please help
Old May 31, 2007 | 12:03 PM
96badbird's Avatar
okay guys i cant remember exactly so i could use a reminder. when adjusting my roller rockers, i know i tighten them till they quit tapping. from there is it a 1/4 turn or 1/2 a turn. please let me know soon guys
Old May 31, 2007 | 12:14 PM
GetaZforgetGT's Avatar
Loose is better.
I go a 1/4 on mine but the lifter manufacture normally has a recommendation.
Like I said, I personally go 1/4 turn.
Old May 31, 2007 | 12:29 PM
BUBBA's Avatar
You obviously have chosen to adjust them with the engine running, so ideally you would loosen each one until it clatters and slowly tighen until they quite down. Could be anywhere between 1/8 and 1 full turn. Usually around 1/2, but could be a little more or less. I would guess that they would be pretty much the same. I would feel comfortable if they wound up being 1/2.
I don't know how much power you lose by going from 1/4 to 1/2 , but I would guess it isn't so much that I would take the chance of being too loose, especially if you have SA RRs, since if the roller comes of the valve stem, you run into problems.JMHO
Old May 31, 2007 | 02:31 PM
You might want to let people know what lifters you are running, so you can get more accurate advice.
Old May 31, 2007 | 04:30 PM
96badbird's Avatar
crane stock replacement lifters
Old May 31, 2007 | 09:17 PM
sam pace's Avatar
I use a vacuum gauge.
loosen them up till they clatter then tighten them down. when your vacuum Rises then falls bring it up to the highest number.
you usually gain about 3-5 in vacuum in your intake.
low tech but very effective
Old Jun 1, 2007 | 08:41 AM
96badbird's Avatar
thanks for all tips guys
Old Sep 7, 2007 | 07:40 PM
96LT1TX's Avatar
sam, how do you use this vacuum guage? I think i am going to try this method soon...
Old Sep 7, 2007 | 08:56 PM
jasonisdn's Avatar
something i found out this week , your oil pressure will play a role in it also. higher oil pressure, from a hv or high pressure pump or tight bearing clearance, you will tend to go 16th to a 8th of a turn. i had mine at half to slightly more and the valves were staying open from 4200rpm. a nice big lean spot on the wide band. adjusted the valves and the car got rich. then the tire popped before we could finish the tune.
G-BODYT56
Jan 14, 2022 11:14 PM
93 RedBird
Nov 15, 2015 08:24 AM
football4life
Oct 4, 2015 07:48 AM
SEOJustin
Sep 24, 2015 04:39 PM
95craz28
11
Sep 12, 2015 07:47 AM
