Adjusting RR's
Old Feb 13, 2008 | 11:34 AM
  #16
ss.slp.ls1's Avatar
Iac?
Old Feb 13, 2008 | 12:26 PM
  #17
asia517's Avatar
Originally Posted by ss.slp.ls1
Iac?
What is Iac?
Old Feb 13, 2008 | 01:06 PM
  #18
2000GTP's Avatar
Originally Posted by asia517
What is Iac?
Idle air control valve as found in the throttle body.
Old Feb 14, 2008 | 10:03 AM
  #19
asia517's Avatar
bad idle when in gear???
I reset the IAC according to shbox and the car now idles fine when in park. when you either put it in gear or touch the gas it stalls. in gear the idle jumps from 500 to 1000 and back down until it finally stalls out. when you hit the gas it just goes up then stalls out. What could this be?
Old Feb 14, 2008 | 10:23 AM
  #20
ss.slp.ls1's Avatar
It would be convenient if you could find someone to swap throttle bodies and MAF's with. Could be your IAC, could be a vacuum leak, I'm only guessing.
G-BODYT56
Jan 14, 2022 11:14 PM
93 RedBird
Nov 15, 2015 08:24 AM
football4life
Oct 4, 2015 07:48 AM
SEOJustin
Sep 24, 2015 04:39 PM
95craz28
11
Sep 12, 2015 07:47 AM
