adjusting rocker arms
Old Aug 23, 2003 | 06:00 PM
AndyCLT1's Avatar
After adjusting valves I can turn some pushrods by hand as it sits. Does this make any sense? I went to zero lash (until I felt a little resistance while turning the pushrods) then a 1/4 turn of the rocker arm nut. Then I tightened the set screw. Now I can turn a couple of the pushrods. This doesn't seem right to me. I did make sure that each lifter was on the base circle of the cam before adjusting. Just making sure this is right before I put the valve covers back on and take it for a ride.
Thanks,
Andy
Old Aug 23, 2003 | 06:04 PM
Lunarson's Avatar
Its normal, the lifters bleed off as you turn the motor by hand.
Old Aug 23, 2003 | 06:08 PM
AndyCLT1's Avatar
I was thinking that may be the cause. I just needed a little piece of mind before putting the covers on and beating on it. Thanks!
Andy
browenb
Parts Wanted
Jul 20, 2015 07:34 AM
9t4lt4z28
Parts Wanted
Jul 19, 2015 06:16 PM
94Form
Jul 17, 2015 10:56 PM
Noer
Parts Wanted
Jul 4, 2015 05:13 PM
