Accel 300 Ignition problem?
Old Jan 9, 2004 | 09:58 PM
Lester 94-Z28's Avatar
So I was workin on my car, and I have an accel Ignition set up that has been workin fine for many years. Last night I changed it back to the stock set up for the heck of it (please dont ask why because I do not have an answer =) Today I go back to the accel ignition, hook up the wires... doesnt start.... I think to myself, oh well i probable mixed the connections up, so I try another combination....same thing, no start, so again i try another combination ..nothing.....I say, Oh well Ill just go back to stock for now. Hook it back up NO START So my question is... Did I screw something up by having the connections messed up? I ran fine last night........
Old Jan 9, 2004 | 10:15 PM
ABA383's Avatar
Smile
Mine quit after 5 years...I hadn't touched anything...one day the car just wouldn't start...I unplugged it and went back to the stock set up..it fired right up...I called LPE and they said that they no longer recommend the 300 because of unexplained failures..I replaced it with an MSD 6A and matching Blaster coil...so far so good.
Old Jan 9, 2004 | 10:26 PM
well whats troubling me now is that it wont start even after I went back to the stock set up, so something else is the problem.
Old Jan 9, 2004 | 10:32 PM
ABA383's Avatar
Oh....I'm assuming you have power..headlights, etc and no starter noise at all...mmmmm all fuses good? what were you working on when you switched back to the stock set up? Its gotta be something silly then...
Old Jan 9, 2004 | 10:53 PM
my94blackz's Avatar
Is the accell grounded well? I had the same prob.
Old Jan 9, 2004 | 10:54 PM
Yea, It cranks strong... just doesnt ignite.
Old Jan 9, 2004 | 11:16 PM
hot_red_z28's Avatar
You blew a fuse, guarenteed. I did the same thing bout 5 times when installin my 300+. If you connected them wrong even once, then the fuse blows, and you wont' be able to start it no matter how you configure it. Open up the fuse box (the under hood one) and check the ignition fuse. I can almost guarentee it'll be popped. I think it's a red one (5 or 10 amp), but I could be wrong...
Old Jan 9, 2004 | 11:31 PM
YUP the ignition fuse was blown, replaced it..... then I pulled the wire on one of the connections that goes into the coil too hard and I broke it, repaired it.........doesnt start....
damn , I thought that fuse was gonna be it.... Would I have blown my coil or opti or is that what the fuse is there for? to protect themselves from idiots like me...
Old Jan 10, 2004 | 12:04 AM
well, check the fuse again, maybe you popped another. If you hooke it up backwards or don't ground it properly, it'll keep popping them...
Old Jan 10, 2004 | 12:34 AM
ishz28's Avatar
When my Accel went out it took the ignition module. little sensor on the coil bracket, 80$, Advance auto zone. The Accel coil and the Opti. Would crank hard, just would not fire over. 430$ later, fired up just fine!
Old Jan 10, 2004 | 12:35 AM
So I just replaced the coil with a spare I had Lying around and it did the trick, Its running as I type. Thanks for all your help guys.
99TransAmWS6
Mar 23, 2015 12:02 PM
97Z28Muscle
Feb 6, 2015 10:44 PM
ferraricameron
Jul 29, 2002 07:46 PM
