Accel 300+
Old May 9, 2006 | 09:37 PM
ChasSidwa's Avatar
Accel 300+
I'm about to install a Accel 300+Ignition with Coil and need a recomendation on what plugs to run with it. Thanks.
Old May 10, 2006 | 11:40 AM
ChasSidwa's Avatar
Re: Accel 300+
Should I stick with NGK TR55 or can I use the Platnium tipped ones?
Old May 10, 2006 | 03:28 PM
WarMachine's Avatar
Re: Accel 300+
If they are the universal wires you'll need the Optispark boots, you can get those from summit or thunder racing.
If they are already made for the LT1's you'll be fine they should be in the kit.
Stick with TR55's will be fine, unless you want to spend the extra dough, go ahead than.
Old May 10, 2006 | 03:47 PM
2000GTP's Avatar
Re: Accel 300+
Depends on how often you want to change your plugs and how much you want to spend. The platinum plugs will last longer but cost quite a bit more. The TR-55s are cheap, but will not last as long as the platinums.
Old May 10, 2006 | 09:30 PM
ChasSidwa's Avatar
Re: Accel 300+
So I can run platnium plugs with an Accel 300+Ignition with Coil?
Old May 10, 2006 | 09:35 PM
revtime's Avatar
Re: Accel 300+
Yes you can, I have run platinum plugs for years with a 300+.
Old May 11, 2006 | 09:29 AM
ChasSidwa's Avatar
Re: Accel 300+
G-BODYT56
Jan 14, 2022 11:14 PM
93 RedBird
Nov 15, 2015 08:24 AM
Matt Dreessen
Sep 9, 2015 09:58 PM
Slayer
Aug 17, 2015 03:55 PM
