ac removal, whats needed?
Old Mar 5, 2005 | 08:44 AM
Mystic97Z's Avatar
hey, in the process of building an engine for my car, i'm taking the asr, air pump and air conditioning.
what needs to be done to remove the air conditioner? thanks.
quick help is appreciated.
-Jason
Old Mar 5, 2005 | 10:50 AM
Brent94Z's Avatar
Super Moderator
Re: ac removal, whats needed?
Are you asking like what type of belt is needed to bypass the AC? Just trying to figure out better what you are asking
Old Mar 5, 2005 | 05:56 PM
Mystic97Z's Avatar
i have my engine out of my car, and i'm not putting the ac back in, lines, condenser, nothing. what do i need to do ? like besides just -not put it back in-
Old Mar 5, 2005 | 07:52 PM
lillbush5555's Avatar
remove the compressior, lines, condensior, dryer (SP on all ) and get this:
http://cgi.ebay.com/ebaymotors/ws/eB...category=38656
Uses stock belt. You can get it on ebay there or at the dealer for a little more
Matt
BTW: Here is a pix of it on my car, http://community.webshots.com/photo/...30035369LTdIWk
Old Mar 6, 2005 | 12:31 PM
Mystic97Z's Avatar
couldn't i just use a shorter belt?
Old Mar 6, 2005 | 01:38 PM
texasTA's Avatar
Here is my question regarding this. I am about to remove the A/C also and relocate the alternator. Is there anyway to retain the Power Steering while removing the A/C and relocating the alternator?
Old Mar 6, 2005 | 03:30 PM
NO...If you use a shorter belt then they would touch each other on the PS pump.
Matt
Old Mar 7, 2005 | 12:21 AM
sick-1's Avatar
I used a 1Le a/c delete pully on my car and it works great, uses stock belt size. Only problem that i have had is that somtimes when i go through a big puddle the belt will slip a little and cause you to loose power steering but not very often.
DirtyDaveW
Dec 1, 2016 05:37 PM
4586
Parts Wanted
Mar 17, 2015 11:24 PM
HectorM52
Parts Wanted
Feb 11, 2015 09:33 AM
NED4SPD
Sep 16, 2002 10:45 PM
mjcent922
Jul 27, 2002 12:42 PM
