AC Problems...
Old Apr 11, 2003 | 08:08 AM
Bad T.A.R.A's Avatar
AC Problems...
What should I check if the compressor wont even click on? I checked the fuse and it seems to be fine. Any thoughts on this
Old Apr 11, 2003 | 09:20 AM
mc63's Avatar
There's a safety low pressure switch that will keep the compressor from running if the refrigerant is low.
Check your charge...
Old Apr 11, 2003 | 09:25 AM
Ya I checked it and it has pleanty of coolant right now
Old Apr 11, 2003 | 03:04 PM
mc63's Avatar
How did you check the refrigerant charge?
Old Apr 11, 2003 | 03:58 PM
We have some gauges and put them on there and it seemed to have enough in there.
Old Apr 11, 2003 | 04:50 PM
mc63's Avatar
How are you checking the pressure without the compressor running?
It will have to run to check both high and low side.
If you jump the low press. switch out the compressor will run.
Check pressure, if it is good, replace pressure switch.
Good Luck,
Michael
MustangEater82
Dec 30, 2005 07:40 AM
Highlander
Sep 15, 2004 08:42 PM
MustangEater82
Sep 30, 2003 12:09 AM
frmula1
Apr 30, 2003 02:07 PM
