AC help.. evap temp sensor
Old Mar 19, 2003 | 04:12 PM
  #16
Zrag's Avatar
Update!
Just got it working. I needed to reset my PCM and add some freon.
I can't understand why it went down to begin with. I let out freon because I thought it hat too much pres due to high 80s yesterday just to add back what I lost.
It's working so far it still may have been the pressure switch.
Also I insulated the line going into the ac coil so that it wouldn't loose too much coolness since headers are close. I also plan to insulate from heat the plastic that holds the coil. That should chill it a bit better.
Still Jordon try to reset the PCM stranger things have happened.
Good luck.
HectorM52
Jul 30, 2017 11:46 AM
AlaskaZ28
Jan 1, 2015 12:30 PM
AlaskaZ28
Dec 10, 2014 02:39 PM
AlaskaZ28
Dec 10, 2014 02:37 PM
JurisAg02
Jul 27, 2002 11:49 AM
