ac delete pulley gain
Old Mar 8, 2006 | 02:10 AM
  #16
Evil Eric's Avatar
Re: ac delete pulley gain
Originally Posted by VK
man, you guys don't have to be aholes about it.
pros:
- Room to work (as TonyK said)
- about 80ish lbs (rough math 100lb = -.1 sec)
- Throttle response tiny bit better
- If condensor removed, better airflow for radiator(tranny cooler if equiped)
- cleaner looking engine bay (which we all know the LT1 needs )
Couldnt have said it better, you'll never have to change the #2 spark plug blindly with busted knuckles again.
Old Mar 8, 2006 | 10:52 AM
  #17
CANTONRACER's Avatar
I would imagine there is some hp gain...it does take some power to turn the a/c even when it is not in use.
I bet the same power as a pulley swap.
Old Mar 8, 2006 | 11:05 AM
  #18
TransAm396's Avatar
they pulley spins free when its not in use.
Old Mar 8, 2006 | 11:07 AM
  #19
V8 Slayer's Avatar
Yes, when the AC is off.. It spins freely, you can spin it your hand incredibly easily.. You wont gain any power...
Old Mar 8, 2006 | 11:16 AM
  #20
Bersaglieri's Avatar
80lbs and 50lbs? I thought the AC Delete was worth maybe 20-25lbs max?
-Dustin-
Old Mar 8, 2006 | 12:26 PM
  #21
The compressor + condenser is about 30#. Add on the lines, separator bottle, evaporator and it goes higher.
Old Mar 8, 2006 | 12:29 PM
  #22
Loadre's Avatar
50# is a fairly good estimate for weight loss, maybe a tad high.
I know that my A/C condensor pulley spun more freely than my delete pulley did.
On a side note, anybody have to change belts when they did this?
Old Mar 8, 2006 | 01:11 PM
  #23
Perhaps I was mistaking the compressor as being 20lbs or something. I think I'll be doing this mod with the H/C install. 40-50lbs of the front end is awesome, plus I dont like A/C anyways. Thats why God made T-Tops
I was wondering how much shorter the belt had to be, I'd ask the belt #, but I already have a different size from my pulley.
-Dustin-
Old Mar 8, 2006 | 01:17 PM
  #24
Loadre's Avatar
After doing this swap it seems as if my belt is a little too tight. The motor acts like it seizes the second you turn the ignition key off.
I remember shoebox once saying there are two different belt sizes for discrepancies between A/C compressor diameter or something. Maybe he can elaborate.
Old Mar 8, 2006 | 01:19 PM
  #25
BlackScreaminMachine's Avatar
its more of a weight saving mod rather than hp increasing mod.
Old Mar 8, 2006 | 01:21 PM
  #26
GreenDemon's Avatar
I thought you could get a 96-97 ss w/out ac? Did it still have the pulley? I figured they would have dropped the entire system and used a different belt.
Old Mar 8, 2006 | 02:02 PM
  #27
The pulley spins relatively freely..but it is rotational weight that must be spun up.
RUENUF
Mar 13, 2016 03:37 PM
Nutty's96
Dec 21, 2015 06:25 AM
colts0455
Sep 22, 2015 02:03 PM
colts0455
Sep 2, 2015 12:41 PM
tnmotown
Aug 10, 2015 11:52 PM
