ac delco/autolite wires wont work
Old Jul 22, 2011 | 01:35 PM
  #16
Re: ac delco/autolite wires wont work
Originally Posted by dennis5374
I spoke with solomon today and he believes that the mad coils are too high voltage for the wires and opti? ...
Read my post. Myself and others have run them for years without issue.
Old Jul 22, 2011 | 01:37 PM
  #17
dennis5374's Avatar
I know I've asked this before but why isbthe difference between the earlier icm's and the 95-97 icm's aside from the price?
Old Jul 22, 2011 | 03:53 PM
  #18
Do you realize we have a spark plug reference chart stickied on the N2O Tech forum:
https://www.camaroz28.com/forums/sho...d.php?t=431689
Old Jul 22, 2011 | 04:00 PM
  #19
I spoke with solomon today and he believes that the mad coils are too high voltage for the wires and opti? Im picking up a oem coil in a couple hours. Im gonna spray my wires down with that hi temp silicone and give it a shot with the oem coil. If this doesnt work ill regap the plugs and throw the super conductor wires on
Go back and read what I posted about the spark gap. Just because a coil is capable of developing a higher voltage doesn't mean it will apply a higher voltage. The voltage builds until it is capable of jumping the plug gap. That is what determines the amount of voltage that builds in the coil. If both a 40,000 volt stock coil (just picking a number as an example) and a 60,000 volt aftermarket coil are used in a system that requires 40,000 volts to jump the gap, they will both produce 40,000 volts. If the system requires 50,000 volts, the stocker can't fire the plug, but the aftermarket coil will, because it can develop more that 40,000 volts.
A plug gapped at 0.040" shouldn't be causing quality wires to arc.
Who calculated your static compression ratio?
Old Jul 22, 2011 | 04:40 PM
  #20
dennis5374's Avatar
The person who built my engine. Idk how he calculates it.he has the build sheet in his office and is closed till monday. 12.4 to. 1 i have not changed my signature yet. I can't even remember specs on anything i know the heads were milled block was decked. I know it will run like crap on anything less than 93 non ethanol super.
Old Jul 22, 2011 | 07:28 PM
  #21
dennis5374's Avatar
Found part of the problem. Junk plug wire sleeves. Cheap ones that look like they have aluminum foil on one side.didn't disconnect the battery. Dropped the wire onto starter and burnt a hole through it. Now wire arcs too that foily crap. Replaced it with different wire and cloth one.dielectric grease too all wires and coil plug ins. Car seems too be running great but i will wait till dark too look for any arc
Old Jul 23, 2011 | 07:50 PM
  #22
dennis5374's Avatar
Problem solved. Delco wires couldn't take the heat from the headers. Put the 8.5s on and runs great. Solomon did an excellent job with the base tune can't wait too datalog it and get it fine tuned. Thanks everyone for your input
ldtantlinger92
Jan 19, 2015 01:26 PM
phoenix95
Jan 8, 2015 02:44 PM
mr28
Nov 23, 2014 11:11 AM
Evilfrog
Aug 7, 2002 11:36 PM
