abs inop light
Old Jan 18, 2008 | 02:27 PM
Lil_Ryan's Avatar
abs inop light
i just put custom sheet aluminum valve covers on my car and now under hard acceleration my abs inop light comes on. i am running the ltcc and the coils are on the valve covers. i was running lt4 valve covers with the coils mounted on those and this was never a problem. is it something to do with the aluminum valve covers or whats the deal.
ryan
Old Jan 18, 2008 | 02:30 PM
Bigrick2324's Avatar
no bud it some times under hard accleration knocks sensor loose it does it to my car to bud
Old Jan 18, 2008 | 03:47 PM
SS MPSTR's Avatar
mine comes on occasionally too. sensor is loose.
Old Jan 18, 2008 | 05:07 PM
96-blklt1's Avatar
i dont mean to steal your thread....but mine is always on. does that mean i need new brakes or something???
Old Jan 18, 2008 | 05:47 PM
Lil_Ryan's Avatar
so i just need to tighten down the sensor. it didnt do it until i swapped valve covers
Old Jan 19, 2008 | 08:22 AM
Guest47904's Avatar
Guest
For 96-blklt1:
The ABS light on all the time is a hard failure and is not from the wheel sensors. When ever the ABS inop light comes on AND cruise doesn't work, suspect the third brake light. GM does not allow cruise or ABS without a working third brake light.
Wheel sensors set a code only after the car starts to roll. That's a soft failure. Each time the power is turned off, the ABS inop light goes off until the car rolls again.
For Lil ryan:
However, one other major reason (at least on this board) that the light sets is plug wires running too close to the ABS wiring. This appears to interfere or cause noise on the wiring from the ABS to the EBCM. My EBCM was defective causing the problem. After eliminating all other possibilities, got one at a JY for $25. I think dealer cost at the time was 170. The JY guy didn't know what it was.
Old Jan 19, 2008 | 03:04 PM
Lil_Ryan's Avatar
what is the ebcm.
Old Jan 19, 2008 | 03:14 PM
Electronic Brake Contol Module..... ABS.
Old Jan 19, 2008 | 06:13 PM
AlwaysCode390's Avatar
Too funny, I did a small burnout for a friend today, and my light came on ... until I shut off the car, and restarted it. It has stayed off since ---
Old Jan 19, 2008 | 09:24 PM
solarofthesix
Guest
Posts: n/a
yea mine does this and im pretty sure its due to plug wires becuase of how i have the routed at the moment....so check your plug routing
Old Jan 20, 2008 | 10:25 AM
96-blklt1's Avatar
ha....yah, i check the third brake light, and that was it! thanks alot. :-)
grabbem88
20
Dec 27, 2015 07:42 PM
jj_burchiel
Mar 21, 2015 12:51 AM
dluna333
15
Mar 13, 2015 12:30 PM
bfmv13trivium
Jan 14, 2015 09:57 AM
Black Sunshine/ 00SS
Aug 24, 2002 03:41 PM
