abs inop
Old Oct 26, 2004 | 10:03 PM
RichyZ28's Avatar
abs inop
my abs inop light is stuck on
only comes on after 10min of driving or when i get on it. does this mean one of my abs breaks is broken or sensor fualt?
Old Oct 26, 2004 | 11:26 PM
S8ER95Z's Avatar
Re: abs inop
I would check your sensors, Mine comes on occasionally.. I just restart the car and it goes way...apears to be random. Maybe a dirty sensor? or a broken one.
Old Oct 27, 2004 | 12:05 AM
Z95m6's Avatar
Re: abs inop
How many miles are on your car? I was having a problem of my ABS inop light coming on when ever i would get on my car hard and as the car got into higher RPMs the light would come on. My car was only charging at about 12.5 volts too. I was also trying to track down a low hp problem so i put in a new fuel pump and Racetronix harness. The car instantly charges at 13.5 volts now and when i get on it the ABS inop light never comes on. I noticed the Fuel pump plugs into the power block as the ABS light so my theory is the fuel pump was drawing too much juice and it would set off the ABS sensor. Its just a theory and could be dead wrong but i would look into it.
Old Nov 28, 2004 | 05:08 PM
NoFear95's Avatar
Re: abs inop
Was doing a search and came across this. My light came on and stayied on. Tracked it down to the wire from the wheel sensor was stuck/melted against my headers. Soon as I fixed it no problems. Would explain why the light didnt come on until it was warmed up.
Old Nov 28, 2004 | 05:22 PM
OBE1 95Z28's Avatar
Re: abs inop
Check for the obvious first, burnt wire, disconnected connector. There are about 50 codes that the ABS system can throw. Get you car scanned for the ABS code if you can't find an obvious cause.
Old Nov 28, 2004 | 06:11 PM
captain_foustas's Avatar
Re: abs inop
i had a simalar probem, turns out a spark plug wire was touching the abs harness
Old Nov 28, 2004 | 06:19 PM
93LT1355's Avatar
Re: abs inop
I'm having exactly the same problem with my car but haven't had the chance to look at it yet. Thanks for some of the suggestions.
Old Nov 29, 2004 | 04:40 PM
slp223's Avatar
Re: abs inop
i have had this problem several time over the years. and it has been a diffrent cause every time. bad wheel hub sensor, bad conection the sensor and metal flake the the rear end sensor from a broken rear end.
Old Nov 30, 2004 | 03:39 AM
Got-LT1's Avatar
Re: abs inop
Happened about two weeks ago to me. The alternator was overcharging (17+ volts) and as soon as I changed it (and replaced the belt, ton of cracks in it) the problem went away.
Old Nov 30, 2004 | 05:00 AM
slopokrodrigez's Avatar
Re: abs inop
How about putting the particulars of your vehicle like yr, mk and model, tranny and mods and include with or without TC and where you are located?
As far as your problem is concerned, someone above said to scan it. Start there. Then reset the code and see if it returns. A soft code such as yours is usually a sensor, however, it will almost always set an ABS INOP within seconds of the car rolling. You said it takes as long as 10 min. Once you've proved the same code returns, you can then trouble shoot it from there.
Dave
Old Nov 30, 2004 | 11:26 AM
RichyZ28's Avatar
Re: abs inop
its a 1997 z28 camaro intake cat back exhuast, sometimes i can drive 40 miles without it going off but mainly goes off when i get on the car.
Old Nov 30, 2004 | 11:36 AM
TobyZ28's Avatar
Re: abs inop
Mine is identical, happens somewhat spurratically.
I can drive a good distance w/out it on, but sometiems itll just go on
Old Nov 30, 2004 | 11:59 AM
BlownF1's Avatar
Re: abs inop
Another common thing to check is the ground wires on the passenger fender next to the RED plastic power block. Clean them up and tighten them good...
IndyZman
Oct 22, 2015 02:17 PM
TGGodfrey
Aug 17, 2015 08:43 PM
tnmotown
Aug 10, 2015 11:52 PM
realistyc
Jul 28, 2015 07:32 PM
