abs inop
Re: abs inop
How many miles are on your car? I was having a problem of my ABS inop light coming on when ever i would get on my car hard and as the car got into higher RPMs the light would come on. My car was only charging at about 12.5 volts too. I was also trying to track down a low hp problem so i put in a new fuel pump and Racetronix harness. The car instantly charges at 13.5 volts now and when i get on it the ABS inop light never comes on. I noticed the Fuel pump plugs into the power block as the ABS light so my theory is the fuel pump was drawing too much juice and it would set off the ABS sensor. Its just a theory and could be dead wrong but i would look into it.
Re: abs inop
Was doing a search and came across this. My light came on and stayied on. Tracked it down to the wire from the wheel sensor was stuck/melted against my headers. Soon as I fixed it no problems. Would explain why the light didnt come on until it was warmed up.
Re: abs inop
Check for the obvious first, burnt wire, disconnected connector. There are about 50 codes that the ABS system can throw. Get you car scanned for the ABS code if you can't find an obvious cause.
Re: abs inop
i have had this problem several time over the years. and it has been a diffrent cause every time. bad wheel hub sensor, bad conection the sensor and metal flake the the rear end sensor from a broken rear end.
Re: abs inop
Originally Posted by RichyZ28
my abs inop light is stuck on
only comes on after 10min of driving or when i get on it. does this mean one of my abs breaks is broken or sensor fualt?
As far as your problem is concerned, someone above said to scan it. Start there. Then reset the code and see if it returns. A soft code such as yours is usually a sensor, however, it will almost always set an ABS INOP within seconds of the car rolling. You said it takes as long as 10 min. Once you've proved the same code returns, you can then trouble shoot it from there.
Dave
