About to start my 383 stroker rebuild. Need help
Old May 29, 2004 | 01:38 AM
stang_killa94's Avatar
Ok i just have a few questions that hours of searching didnt answer. Can i buy just the crank and install it? or do i need to upgrade other parts? if so what other parts should i upgrade? Can i keep my stock pistons? whats a good cam for torque and will pass emissions?
Basically the way i wanted to do this was.........1) Buy the crank, install it 2) cam with rockers (pushrods?) and a HD timing chain. Would i be able to do that?
Old May 29, 2004 | 01:58 AM
97WS6SCharged's Avatar
You will need a different set of pistons that are made for the longer stroke. And you will need to clearance the block to accept the longer crank throws. You're also going to want to replace the bearings while you're at it. The stock 5.7 rods will work, but they won't be optimal.
Old May 29, 2004 | 02:58 AM
So basicallu the whole engine needs to be broken down and have the blocked worked on?
Old May 29, 2004 | 03:02 AM
Rich_z28's Avatar
Ummmm, yep.
Old May 29, 2004 | 03:27 AM
Originally posted by Rich_z28
Ummmm, yep.
What he said.
D1SC383LT4
Jan 1, 2016 01:56 PM
D1SC383LT4
Jan 26, 2015 01:41 PM
Killer94z
Jan 13, 2015 12:06 PM
spearous
Jan 12, 2015 11:03 AM
