? about rocker studs and valve lash
Old May 30, 2004 | 07:57 AM
wicked_95z's Avatar
Are there certain valve studs that are suppposed to be used when going from stamped rockers to roller. I have a couple that are bottoming out on the nut of the stud and its hard to adjust them.
Secondly, has anyone set their valves at o lash and left it there with the Comp R lifters. My car was idling at about 600rpms so I thought my valve adj was too tight so I back them all off to about 1/8 turn past 0 lash and it still idles low. Could it be a result of the first question?
Old May 30, 2004 | 02:42 PM
med_reject's Avatar
thats funny. My engine builder firmly believes i should go zero lash with 1.6 RR and comp R lifters. I always hear people going 1/8 over, even 1/4 over.
I'd like to know as well if anybody else has gone zero
Old May 30, 2004 | 02:43 PM
PoorMan's Avatar
I had the some problems with the stock studs hitting. I switch to ARP studs and they cleared. They have a lower profile nut.
Old May 30, 2004 | 03:52 PM
Spinner's Avatar
Zero is ideal for the most power. But unless you have a sump system, the lifters will bleed down, and it could cause problems. 1/8 over is more then satisfactory. Any more is nothing but safety and quietness, at the cost of power.
Old May 30, 2004 | 05:31 PM
PoorMan's Avatar
Spinner, are those Comp RR lifter specific instructions? I had to go 1/2 past for stock lifters.
Old May 30, 2004 | 06:26 PM
Spinner's Avatar
Thats for any fresh lifter. Comp R or stock, shouldnt really matter, though the Rs are much stiffer and don't bleed down as much. Stockers might need a little more as a safety margin, but again, 1/2 past is WAY overkill.
HectorM52
Jul 30, 2017 11:46 AM
KamikaZ28
May 28, 2015 12:45 AM
FredM
Apr 10, 2015 02:56 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
alphaauto
Jan 23, 2015 07:42 AM
