about to pull my motor
Old May 4, 2004 | 12:11 PM
DarkRider's Avatar
quick question before I pull my motor - is it ok to pull the motor from aluminum heads? just want to make sure beforehand.
thanks
Old May 4, 2004 | 12:53 PM
Will84's Avatar
Better to pull the car... and pick the motor up.
http://ken.lowrance.com/Projects/Hea...ineRemoval.htm
Old May 4, 2004 | 12:54 PM
ZDriver96's Avatar
dropping it out the bottom is easier.. 4-6 hour job to drop it from the bottom. I did mine a couple days ago
Old May 4, 2004 | 01:00 PM
DarkRider's Avatar
The car was totalled and I am parting it out. the only thing left in the car is the motor. It will be very easy for me to pull it through the top I just want to know if it is ok to lift from the heads.
Old May 4, 2004 | 01:04 PM
Will84's Avatar
It should be ok. I don't think that the bolts you'll be lifting with will damage the threads or warp anything. I did it a few years ago. 40k on the motor and no problems with anything... so I guess it didn't hurt anything.
Old May 4, 2004 | 02:51 PM
carlos64030's Avatar
You'll be fine pulling the motor by the heads. There's some pics in my sig of me putting the motor back in with the chains attached to the heads.
Old May 4, 2004 | 04:01 PM
DarkRider's Avatar
what about pulling it where the exhaust manifolds bolted on
Old May 4, 2004 | 04:04 PM
95_LT1_6SPD's Avatar
why not just go where the intake manifold bolts up, like a normal human?
Old May 4, 2004 | 05:37 PM
Old May 4, 2004 | 05:51 PM
lt1camaroman93's Avatar
get a happy hooker and take it out by the intake
Old May 5, 2004 | 08:41 AM
Will84's Avatar
that would be the heads
Old May 5, 2004 | 01:33 PM
DarkRider's Avatar
yes I know - I was wandering if it is ok to pull from there so the intake didn't have to come off
but it doesn't matter - I pulled the intake and the motor is out.
Now its time to build a 383
thanks for the help
Josh
DirtyDaveW
Mar 15, 2015 07:01 PM
transam_388
Mar 15, 2015 11:53 AM
Chris Anderson
Jan 27, 2015 08:30 AM
Darth Xed
13
Jul 22, 2002 12:45 PM
