About to install a Radiator.
Old 10-01-2004, 02:38 PM
95z28 -quicksilver's Avatar
Location: Austin, TX or Texas State University at San Marcos
Hey guys my radiator cracked and i ordered a new stock one to replace it. It looks simple enough, and i was just wondering if you guys had any tips for me. Thanks.
Chris
95z28 -quicksilver is offline
Old 10-01-2004, 02:45 PM
MEAN LT1's Avatar
Re: About to install a Radiator.
Good luck and it always helps if you had another person to help.
MEAN LT1 is offline
30696bird's Avatar
If you did the mods in your sig; This should be a breeze! Really it is very easy........take 3 bolts out of the top plastic piece that holds it on and slide it out. That's a VERY hard job to screw up.
30696bird is offline
Old 10-01-2004, 02:58 PM
Do i need to drain the coolant like i had to to do the optispark?
Old 10-01-2004, 03:02 PM
texasTA's Avatar
You need to drain all the coolant. Disconnect all hoses going into the Radiator. Take off the Radiator shroud. Get a friend to hlep you unclip the radiator from the A/C Condensor. Remove old rad. INstall new rad. Hook up all the hoses. Replace the coolant. And finally, just bleed the system.
Good luck, it is very easy
texasTA is offline
Old 10-01-2004, 03:44 PM
CamaroBoy96Z28's Avatar
I did it by myself. Its easy. Drain all the coolant from the radiator and the block. I only took out the knock sensor and didnt bother with the driver's side drain. Remove and replace...all there is to it.
CamaroBoy96Z28 is offline
Old 10-01-2004, 07:42 PM
Sweet, thanks guys. I'll be doing it tomorrow, along with plugs and wires. Appreciate it fellas.
Chris
11-18-2023 07:21 PM
Victor Lamb
08-26-2017 02:52 PM
1996LT1Z28
04-14-2015 07:15 PM
zxtce
04-01-2015 01:07 AM
Magenta_Hearts
03-25-2015 10:24 AM
Quick Reply: About to install a Radiator.
