About to install a Radiator.
Old Oct 1, 2004 | 02:38 PM
95z28 -quicksilver's Avatar
From: Austin, TX or Texas State University at San Marcos
Hey guys my radiator cracked and i ordered a new stock one to replace it. It looks simple enough, and i was just wondering if you guys had any tips for me. Thanks.
Chris
Old Oct 1, 2004 | 02:45 PM
MEAN LT1's Avatar
Re: About to install a Radiator.
Good luck and it always helps if you had another person to help.
30696bird's Avatar
If you did the mods in your sig; This should be a breeze! Really it is very easy........take 3 bolts out of the top plastic piece that holds it on and slide it out. That's a VERY hard job to screw up.
Old Oct 1, 2004 | 02:58 PM
Do i need to drain the coolant like i had to to do the optispark?
Old Oct 1, 2004 | 03:02 PM
texasTA's Avatar
You need to drain all the coolant. Disconnect all hoses going into the Radiator. Take off the Radiator shroud. Get a friend to hlep you unclip the radiator from the A/C Condensor. Remove old rad. INstall new rad. Hook up all the hoses. Replace the coolant. And finally, just bleed the system.
Good luck, it is very easy
Old Oct 1, 2004 | 03:44 PM
CamaroBoy96Z28's Avatar
I did it by myself. Its easy. Drain all the coolant from the radiator and the block. I only took out the knock sensor and didnt bother with the driver's side drain. Remove and replace...all there is to it.
Old Oct 1, 2004 | 07:42 PM
Sweet, thanks guys. I'll be doing it tomorrow, along with plugs and wires. Appreciate it fellas.
Chris
Nov 18, 2023 07:21 PM
Victor Lamb
Aug 26, 2017 02:52 PM
1996LT1Z28
Apr 14, 2015 07:15 PM
zxtce
Apr 1, 2015 01:07 AM
Magenta_Hearts
Mar 25, 2015 10:24 AM
