??? About Heads Wapring
Old Jul 12, 2003 | 12:30 PM
InjectedSS's Avatar
well i did it AGAIN last night i fu*kin forgot to turn my damn electric waterpump on again after doing some wiring that required me to have the key on so i turned the waterpump off with the switch i have mounted and i forgot to turn it back on and i went driving and got the car up to like 250* before i noticed it this is like the third time i have done this in the past month and im wondering if i should pull the heads and have them resurfaced again?
the car appears to be running fine but im not a "well i think everythings ok" kinda person.. the head gaskets are about a month and a half old and the heads were milled last time the gaskets were put on so what do u guys think? also the car never really had a major overheating scene when it got too hot but thats cause the waterpump wasnt flowing the hot coolant! it did however force about 3/4 gal of coolant each time i ran the car without the waterpump just cause of how hot it got!
thanks
Old Jul 12, 2003 | 01:29 PM
slimdawson's Avatar
I wouldn't worry about it. Last winter I forgot to add coolant and one night I was leaving my parents house, the car overheated. I am like, this is the coldest night in winer, and my car is running hot. I pulled over to find ice in the radiator. I let the car run until it got hot, then let it cool a bit hoping the water in the block would eventually melt the rest. After an hour of that, I limped it back to my parents. Driving with it on for about 30 seconds and coasting till it went down enough. It saw a lot of hell that night but has given me no problems since. I spray it to and have since then. No problems.
Old Jul 12, 2003 | 11:42 PM
JordonMusser's Avatar
West South Central Moderator / Special Guest
yea, just drive teh damn thing. if nothing is wrong, no reason to pull it appart.
Old Jul 13, 2003 | 12:38 AM
kmook's Avatar
Advanced Tech Moderator
Most likely it is fine, Jordon put it well.
I have a question though. Why have the pump on a manual switch? All your doing is allowing the chance to forget to turn it on, just wire it so it comes on automatically...
Old Jul 17, 2003 | 02:16 AM
InjectedSS's Avatar
just cause i like to turn it off when im programming the computer.. or if im doing other crap that requires me to have the ignition on but the car not on! also when im sitting in the pits waiting in line i like to warm my bottle up and not have the WP going as well! i just need to quick FORGETTING!!! im installing an autometer tri-alert so i can hook it up to my water temp guage and that way when if i forget again and the car gets to 210* my big red warning light will come on
aight playa just makin sure i like to be precautious and sh*t
Old Jul 17, 2003 | 02:20 AM
revtime's Avatar
Precautious.
There is a new word.
Put a sticky note on your dash soes to remind yous to turn the damn thing on.
Old Jul 17, 2003 | 02:26 AM
InjectedSS's Avatar
Originally posted by revtime
Precautious.
LOL
Old Jul 17, 2003 | 02:54 AM
RedPhenx's Avatar
why dont you wire it into start not run, so it will only come on when you actually crank the car vs having in the run position?
Old Jul 17, 2003 | 02:58 AM
revtime's Avatar
It can be beneficial to have control over the fans so you can cool the car in the staging lanes.
You just have to remember that the you control the fans not the PCM.
Old Jul 18, 2003 | 11:38 PM
InjectedSS's Avatar
Re: ?
huh well then the waterpump would only work as you crank the car! once you let off the key cyl to stop cranking then the waterpump would turn right back off! think about it, once you stop cranking, the leck cyl springs back into the RUN position
Victor Lamb
Aug 26, 2017 02:52 PM
Roadie
Feb 16, 2015 10:34 AM
NewsBot
Jan 29, 2015 07:10 PM
NewsBot
Dec 28, 2014 06:20 PM
