A4 Trans Problem
I have a problem with the A4 in my 95 Camaro. It appears that first and overdrive are gone. Unless you pull the shifter down into low, it tries to take off from a stop in third. It was rebuilt by a friend who worked for a GM dealer a few months ago. He's moved and I need to start somewhere. Does anyone have any ideas? Thanks ahead of time for all your help.
Your transmission is in limp mode. Double check your main harness connector on side of transmission as well as the Output Speed Sensor connector at the back of the transmission. Also check all of your fuses in the fusebox. That should get you going.
Kevin
Kevin
Sarahrope64
Nov 27, 2014 11:17 AM
