A4 speed sensor???
Old Jun 15, 2004 | 10:05 AM
gamecockfan04's Avatar
A4 speed sensor???
I noticed this weekend when I was under my car that I have a slight trans fluid leak coming from my speed sensor and im guessing its the ring needs replacing. My question is if I remove the speed sensor is the trans fluid going to drain out? and also what exactly is the function of the speed sensor? and last, there only $25 at Advance Auto, so should I just replace the whole unit?
Old Jun 15, 2004 | 03:53 PM
Why waste money on a new sensor if it is working? Just get a new o-ring. If you elevate that part of the car/transmisison, I doubt much fluid will come out when the sensor is removed. The sensor's input is important for shift calculations as well as the speedometer.
jj_burchiel
Mar 21, 2015 12:51 AM
AlaskaZ28
Jan 1, 2015 12:30 PM
AlaskaZ28
Dec 10, 2014 02:39 PM
AlaskaZ28
Dec 10, 2014 02:37 PM
Jul 4, 2005 05:00 PM
