A4 question
Old Mar 8, 2007 | 11:53 PM
jzealy123's Avatar
A4 question
I just replaced heads on my car and for at least the past few days I had the front end of my car up to do the wires/exhaust ect. Noticed fluid on the ground, assumed it was oil or PS fluid. Finally got the car running and noticed that the transmission was slipping. Checked the fluid and it was bone dry almost. I put about 3 quarts into it and it is back to the normal level. Anyone ever had any issues with tranny fluid leaking if the car was jacked up? I didnt touch the transmission or anything around it while doing the install and its never had a problem leaking or slipping before. The car has 130k on it, but the transmission was replaced around 75-80k. Also even now that the fluid is back to normal it still seems to slip a little. Thanks for the help.
Jason
Old Mar 9, 2007 | 12:29 AM
1FstFormulaV8's Avatar
I could be wrong, but I believe there is a weep hole on the transmission that prevents the transmission from being over filled. I'm not sure what angle it needs to be at for fluid to come out of it. I'de imagine it is pretty steep.
Old Mar 9, 2007 | 09:52 AM
2000GTP's Avatar
If you are leaking that much fluid, it should be noticable somewhere. Check all your tranny cooler lines and the tranny tailshaft for starters.
Old Mar 9, 2007 | 02:29 PM
Texas_96_Z's Avatar
Mine slipped at WOT after it sat for a year. Fluid was low, so I filled it to correct level and still slipped. Put in some Slick 50 Transmission Treatment and it's good to go. That stuff is so thick it took 10 minutes to pour it in. But it worked.
dluna333
15
Mar 13, 2015 12:30 PM
jasonduaine
Mar 7, 2015 09:44 AM
30thZ4C
Wheels and Tires
Jan 29, 2015 06:03 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Hurin
Dec 13, 2014 07:38 PM
