A4-M6 Swap problems (just when I thought everything was good)
We took it off the jacks and put the interior together, started her up and now it won't go anywhere, here's what the symptoms are:
The clutch pedal sits like it's half way pressed in, doesn't come up all the way. When we first pushed in the clutch, it leaked a little bit of fluid. I'll put it in gear, and the lights will dim.
Is the clutch just not engaging? Could the master cylinder/slave cylinder be shot? Am I screwed? Do I need to just take it to someone and prepare for my pocketbook to get raped? Anyone in the area (northern VA) who could take a look at it for me?
If you have any other questions that would help you figure tis out with me, feel free to ask. I leave for school next wednesday, kind of need my car to go there.
Thanks for your help
did you get a new computer? You will need a new computer with your manual tranny b/c that sets all your RPMs, speed, etc. It might also reflect upon your question. Can pick one up from a junkyard for $40. (I would do that before taking it anywhere). good luck
well, i attemped to bleed the clutch system today, and it just leaked brake fluid from the master cylinder, there is a rip in it.
So I ordered a new one today, it'll be here tomorrow, hope that helps.
The electical system seems to be kinda weak too, the car stutters as it turns on, and when i hit the lock button on my remote the honks are quieter then usual, could that just be from it not being turned on for 2 weeks?
I'd put money on it being the master/slave cylinder if there's a leak. Ignore the comment about the ecu. I'm still driving on my automatic ecu that hasn't been reprogrammed after the swap. Its unnecessary for operation, and if you have an obd-1 car, the only codes it will throw is the tcc lockup and transmission shift solenoid error. Does not affect engine performance at all.
