In the middle of clutch install! torque spec?
Old Aug 7, 2003 | 08:27 PM
FireAm94's Avatar
Installing a SPEC stage 3 ceramic 6 puck....what do i need to torque the bolts in the clutch to? Already torqued the flywheel bolts....just need the clutch bolt specs now.
Thanx
Joe
Old Aug 8, 2003 | 01:17 PM
zman_virg's Avatar
TORQUE SPECS
The torque are as follows: flex plate 22 ft lbs., flywheel 74 ft lbs.,
flywheel housing bolts 35 ft lbs., trans brace bolt/screw37 ft lbs.,
trans brace nut 37ft lbs., trans bolt screw26 ft lbs.
Old Aug 8, 2003 | 01:20 PM
FireAm94's Avatar
No clutch bolts? I need the specs for the clutch bolts that go into the flywheel.
Joe
Old Aug 8, 2003 | 01:35 PM
zman_virg's Avatar
The flex plate bolts are the ones your talking about right. I posted them.
Old Aug 8, 2003 | 01:40 PM
FireAm94's Avatar
No the flex plates are the automatic version of a flywheel....it bolts to the crank.
Joe
Old Aug 14, 2003 | 04:29 PM
zman_virg's Avatar
Sorry I typed it in wrong. The pressure plate bolts are 22 ft lbs.
Old Aug 14, 2003 | 05:14 PM
FireAm94's Avatar
I got it....went 35lb-ft....I later found out SPEC recommends 32 lb-ft. Thanx for posting.
Joe
BPS
9
Mar 5, 2015 10:51 PM
HectorM52
Jan 30, 2015 11:08 PM
Jason Short
Jan 19, 2015 06:34 PM
